Date/Time: Thu, 08 Oct 2026 15:07:27 +0000
Installing Sierra Charts After Not Being Able to Open
View Count: 716
| [2022-06-07 18:02:40] |
| L2Ltrades - Posts: 65 |
Hello, I was able to run SC until yesterday evening but wasn't not able to open seirra charts after repeated attempts syddenly this morning. I uninstalled and installed the software. It shows that the installation was done, but the usual desktop icon does not show up and I cannot find the Sierra Charts folder either on my laptop that is usually created. It gives an error saying path not found. Please assist. Milind. Date Time Of Last Edit: 2022-06-07 18:02:55
| [2022-06-07 18:13:42] |
| John - SC Support - Posts: 48151 |
There appears to be an issue with the installation right now. We are looking into it and will let you know when we have it fixed. In the meantime, you can use the Zip Installer. Refer to the information here: Software Download: Sierra Chart Zip Installer For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2022-06-07 18:31:26] |
That worked. Still waiting for everything to load up. Thank you.
| [2022-06-07 20:48:23] |
Just letting you, and anyone coming across this post - that the issue with the installer has been fixed.
