Date/Time: Thu, 08 Oct 2026 15:06:36 +0000
[User Discussion] - assistance for coding 2 formula
View Count: 930
| [2022-06-07 16:26:00] |
| User702340 - Posts: 12 |
Hello there, I am totally dumb with tech, but would like to try the following 2 studies. Wonder if this is within your domain of help, and if so, kindly help for coding the below two formula for me and putting on the 'add custom study' section for me so that I can try them. If something like this already exist in the analysis library, pls kindly let me know. 1st study called 'proxy 1'(or whatever name you may designaate = Moving Average (Open - Close, 9 Bars used in average)/ Moving Average (High - Low, 9 Bars used in average)*100 - open - close with the choice of absolute value or sign value - bars in average may vary in setting 2nd study called 'proxy 2' = MovingAvg (open - close, 9 bars used in average)/MovingAvg (high - low, 9 bars in average)*50 + 50 thank you for your help |
| [2022-06-07 16:34:44] |
| John - SC Support - Posts: 48151 |
This is not within the realm of our support. Therefore we have set this as a User Discussion, as other user's may be able to help you put together the studies to do what you want.
| [2022-06-07 22:00:11] |
| Sawtooth - Posts: 4356 |
You could create each study using a combination of six or seven native studies, OR You could create each study with a single Spreadsheet Study study, OR You could code a custom study using ACSIL for each. I can give you some tips on either of the first two, if you want to try it yourself. OR If you don't want to try it yourself, you can contact me here for a quote: sawtoothtrade.com/contact.html If you want a custom ACSIL study, there are others on the forum that might help. |
