Date/Time: Fri, 23 Oct 2026 22:21:54 +0000
Pinning cahrt on top
View Count: 852
| [2022-06-06 23:07:30] |
| User117194 - Posts: 17 |
I have detached my chart but how do I pin it to sty on top? It does not automatically do this where do I select? Thankjs |
| [2022-06-07 13:49:45] |
| John - SC Support - Posts: 48317 |
On the detached chart, select Window >> Always on Top. If you also want that window to be visible when you change between chartbooks, then also select Window >> Window Always Visible. Refer to the following: Window, CB and CW Menus: Always on Top (Window) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
