Date/Time: Thu, 08 Oct 2026 15:07:48 +0000
Vwap Reset Ie Anchor
View Count: 1913
[2022-06-06 13:37:06]
Jaydtrade - Posts: 123
IS there a way to anchor the VWAP from a certain high or low? for example on bookmap I can reset the vwap to a specific area. Trying to do this over multiple time frames with several vwaps.
[2022-06-06 16:38:58]
John - SC Support - Posts: 48151
In the Volume Weighted Average Price you can specify a Date and Time from which the VWAP will start. Refer to the following:
Volume Weighted Average Price (VWAP) with Standard Deviation Lines
[2022-06-07 18:27:50]
Well I am not a study genius but thats not what I am trying to accomplish. If you have ever used bookmap you can reset the vwap to start from a high or low on the chart. I would want to use multiple vwaps from highs and lows on a daily. Is this possible on SC? Where I can just right click and set it to a certain spot?
[2022-06-07 18:35:52]
Like an Anchor VWAP
[2022-06-07 20:52:08]
You can have multiple VWAP studies on a chart. And you can specify the start date and time and what Price Level (Open/High/Low/Close) to use. So it sounds like it can accomplish the same thing, except that there is not the option to click and place the anchor point.
[2022-06-08 05:32:34]
Using SC Since 2020 - Posts: 150
@jaydtrade
video on how to add anchored vwap in Sierra Chart: https://youtu.be/ykqs3J7PT30
[2022-06-08 07:21:05]
User877753 - Posts: 152
You can also draw from any time of the chart using the Draw Volume Profile drawing tool
Volume By Price Study: Description
using only SG5 VWAP.
