Date/Time: Mon, 23 Nov 2026 07:36:43 +0000
Upload Chart not working anymore.. Alt+shift+8
View Count: 705
[2022-05-27 14:47:57]
SabikiSensei - Posts: 76
So when I press edit -> screen images -> upload chart, nothing will pop up with the link copied to the clipboard anymore.. I will press 'upload chart' and nothing happens after. Alt+shift+8 doesn't work either.. i also checked the log with all the links.. it does not update anymore. ive had this problem for 1.5 months now actually, and been downloaded my charts instead but it is alot more cumbersome than pasting a link.
[2022-05-27 15:58:20]
After you select "Upload Chart" check your Message Log and see if there is anything in there regarding an issue with the process. Or copy and paste your entire Message Log to this thread for us to look at. Follow these instructions to do this:
Also, after you select "Upload Chart", are you able to continue to work with the system, or do you need to select Escape or some other key first?
[2022-05-27 17:03:28]
Ah sorry, It seems like I hit the maximum number of images. Will have to delete them
