Date/Time: Sat, 14 Nov 2026 06:19:57 +0000
[Programming Help] - DOM Depth Totals
View Count: 1026
[2022-05-21 20:34:35]
User39772 - Posts: 311
is it possible to access the DOM Depth Totals for Bid and Ask via ACSIL for processing it within a study.
I am aware of example SCSFExport scsf_DepthOfMarketData(SCStudyInterfaceRef sc but found that only NBBO is used, I need the sum of Bid/Ask Volume depending
on the depth set for the chart.
Please advice.
[2022-05-24 06:05:06]
Hello, can you answer that question ?
[2022-05-24 07:43:12]
User431178 - Posts: 910
You need to look at the code for SCSFExport scsf_DepthOfMarketData(SCStudyInterfaceRef sc) again.
It loops through all available depth data and outputs each value to a chart bar index.
Instead of doing that, you can easily change the code to sum the depth values, giving you the totals.
