Date/Time: Sat, 14 Nov 2026 06:19:59 +0000
Suggestion
View Count: 827
| [2022-05-21 07:47:59] |
| Gasoil - Posts: 18 |
I would like to ask if there is a simple way of having year lines in the charts because in the scale if i,m in a daily chart the month and the year is colored in a black box.So if we are scrolling fast we have to stop to see where is a specific year.The grid does not support years and the timeline is for intraday. you already have the bar selection and we can select 252 bars that can emulate a trading year but starts from the present day if we had a way to specify a starting date that bar selection could do the job of having year lines. The other way would be to differentiate year from months in the scale but i f think that would be more difficult to do.
| [2022-05-23 14:15:52] |
| John - SC Support - Posts: 48527 |
Use a 12 month interval for the Vertical Grid. In other words, set the following in Chart Settings >> Grid: - Vertical Grid Interval Type: Months - Vertical Grid Interval Value: 12 For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2022-05-23 14:20:18] |
if we had a way to specify a starting date that bar selection could do the job of having year lines. You can also control the starting date in the chart:https://www.sierrachart.com/index.php?page=doc/ChartSettings.html#UseDateRangeFromTo Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2022-05-24 02:51:13] |
Thank you. i did not sow that possibility of months and vertical grid interval value. It's working.
