Date/Time: Wed, 11 Nov 2026 16:53:37 +0000
DOM Buy and Sell Qty for consolidated ticks
View Count: 1185
[2022-05-18 10:08:06]
User396 - Posts: 61
DOM Buy and Sell qty are working fine for default tick. But if I change default tick size to 1 point for NQ, DOM shows quantity for each tick and there is no space for 4 numbers. So DOM shows all Buy and Sell quantity for all these ticks superimposed on each other which makes them unreadable.
is there anyway DOM can consolidate all Buy and Sell quantity so that it can be readable for consolidated ticks? sometimes NQ moves fast and I would like to have MBO functionality with 1 point. I would like to see only one Buy and Sell quantity for each point.
thank you,
b
[2022-05-18 14:45:47]
John - SC Support - Posts: 48493
Refer to the following setting:
Chart Settings: Market Depth Combine Increment in Ticks (Chart >> Chart Settings >> Market Depth menu)
Just be aware that this only applies to the Bid and Ask Size columns. There is not a way to combine the other market depth columns.
[2022-05-18 18:38:51]
User396 - Posts: 61
thank you, problem solved!
