Date/Time: Mon, 30 Nov 2026 07:44:29 +0000
Tick chart wit standard service package 3
View Count: 691
| [2022-05-10 16:53:59] |
| User886069 - Posts: 17 |
Tried to set all things up , but cant figure it out for hours > My tick chart is not accurate , set global settings and chart setting right (i hope) Can you see the image below and give some feedback? |
| [2022-05-10 16:54:51] |
Other settings Screebshots
| [2022-05-10 17:46:19] |
You have a 400 Range chart, not a 400 trades/tick chart. Refer to the information at the following link for the setup for a Tick chart: Chart Settings: Number of Trades Per Bar (Chart >> Chart Settings >> Bar Period >> Intraday Chart Bar Period Settings >> Bar Period Type) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
