Date/Time: Mon, 30 Nov 2026 07:44:32 +0000
Chart Drawings
View Count: 744
| [2022-05-10 10:10:09] |
| andreaslovesstocks - Posts: 15 |
Hello, Is it possible to have the chart drawings ''save'' per symbol and not per chart? Meaning - I have in the example attached two different rows of (top is linked to ''1'') - bottom linked to ''2''. Example: I had drawings for Symbol VAXX as you can see on the bottom chart - I want to have them now on the top. I am aware that the drawings are per chart - not symbol - still wondering if there is any way to make this work |
| Attachment Deleted. |
| [2022-05-10 16:38:54] |
Actually, drawings are per chart and per symbol. Refer to the following for how to copy drawings from one chart to another: Chart Settings: Copy Chart Drawings from Chart #'s (Chart >> Chart Settings >> Chart Drawings menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
