Date/Time: Mon, 30 Nov 2026 07:44:30 +0000
Historical data
View Count: 784
| [2022-05-10 04:05:41] |
| User606770 - Posts: 7 |
I need to know how I can get more forex historical data whether it be intraday or other. Please forward me to the documentation that clearly and concisely explains this! If I have to upgrade that's fine just lay out what I need to do. Thanks again! |
| [2022-05-10 07:58:56] |
Refer to: Historical Intraday Data (Missing Data / Download Errors / Viewing More Data): Downloading/Viewing More Historical Intraday Data Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2022-05-10 14:41:48] |
I've already done this. It did not give more historical data!
| [2022-05-10 17:08:10] |
You should be able to get data back to about 2007. Refer to the information here: Sierra Chart Real Time and Historical Forex and CFD Data Service: What is Included Are you trying to get data further back than that? For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2022-05-10 17:15:08] |
Yes!
| [2022-05-10 17:51:21] |
We simply do not have it. You can see if IQ Feed has it. Refer to the information here: DTN IQ Feed Data Service For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
