Date/Time: Sat, 21 Nov 2026 06:09:09 +0000
Importing Tick by Tick csv File
View Count: 853
| [2022-05-06 14:42:28] |
| Ankn - Posts: 11 |
I have a large csv file with tick by tick data in the following format. Date, Time, Price, Volume Is this importable under the heading: Date, Time, Close, Volume I see that the header is optional which is fine I just want to make sure the format is acceptable for tick by tick. Chart setting bar period is on Number of trades per bar. |
| [2022-05-06 15:27:24] |
| John - SC Support - Posts: 48610 |
Refer to the following for a list of acceptable formats: Text/CSV Data Format: Supported Data Line Formats For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2022-05-06 15:48:29] |
| Ankn - Posts: 11 |
Correct. My only question is if close is interchangeable with price. There's no real "close" as its not an aggregation period its tick by tick. I would think yes they are interchangeable.
| [2022-05-06 16:16:43] |
You can import the data given the format you have. You will just have to make sure that the data is showing as you expect it to be after you import it.
