Date/Time: Tue, 17 Nov 2026 10:13:20 +0000
Break even
View Count: 725
| [2022-05-03 19:26:39] |
| Marlin46 - Posts: 34 |
I have tried multiple wasy to get 1 contract to move to break even +1 at 5 ticks can you share the settings to make that happen please? Thanks
| [2022-05-03 23:50:47] |
| John - SC Support - Posts: 48547 |
The example at the following link gives you the exact breakeven settings you need for what you want to do. You can ignore the particular Stop order type being used. Attached Orders: Target with Move to Breakeven and Trail Stop Example For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
