Date/Time: Sat, 14 Nov 2026 08:04:04 +0000
data
View Count: 666
| [2022-05-03 15:59:21] |
| User491428 - Posts: 87 |
Data TT appears to have better data than Sierra! Eg yesterday's daily high is higher in TT than in sierra and there are also other deviations |
| [2022-05-03 16:19:46] |
Where are you looking at the daily high? In a Historical Daily Chart? Provide an image of the chart by following these instructions: Support Board Posting Information: Attaching or Posting a Screenshot/Image (Optional) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2022-05-03 19:38:13] |
Only in a Intraday chart! 10 points between TT and Sierra, thanks are too much!!,
Date Time Of Last Edit: 2022-05-03 19:38:33
