Date/Time: Sat, 14 Nov 2026 08:04:06 +0000
Dom Graphic settings
View Count: 3425
| [2022-05-03 12:44:13] |
| User933209 - Posts: 47 |
I would like to know if there is a setting to change the color of the middle / quotes part of the dom. Thank you
| [2022-05-03 14:07:15] |
There are a lot of color settings for the Chart/Trade DOM. Not totally sure what you are referring to but refer to all of the settings here: Customizing Fonts, Colors, Line Styles, and Widths for Chart Trading, Chart DOM, and Trade DOM Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2022-05-03 14:32:44] |
I am referring to the current price / market price field of the DOM. I cannot find it, if it is an available option.
| [2022-05-03 16:21:27] |
| John - SC Support - Posts: 48527 |
The Price Ladder uses the color from the Trade DOM Background Color. So if you have turned off the Trade DOM Bid Background and Trade DOM Ask Background, then you can see the general background color and adjust. Note that you can also change the Buy/Sell Columns background separately. Refer to the information here: Customizing Fonts, Colors, Line Styles, and Widths for Chart Trading, Chart DOM, and Trade DOM: Trade DOM Background Color For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2022-05-03 17:56:11] |
Yes. I know I can change the general background color. For example. My general background color is currently white. My Bid column is Blue, Ask column is Red. The middle column, where the prices are shown - this is the column color I want to change (it is currently white, matching the general background). While leaving the white background for the VP on the dom.
