Date/Time: Sat, 14 Nov 2026 08:04:05 +0000
Volume by Price Study
View Count: 956
| [2022-05-02 17:25:29] |
| User39772 - Posts: 311 |
Hello, how can I modify the font size in the VbP Study if I want display the Volume numbers, e.g. 1234 x 4321 ? Is it possible in the numbers bars study to merge levels similar to "Ticks per Volume bar" in the VbP Study ? |
| [2022-05-02 20:53:44] |
| John - SC Support - Posts: 48527 |
Refer to the following: Volume By Price Study: Volume Numbers Text Color and Size (SG7) Is it possible in the numbers bars study to merge levels similar to "Ticks per Volume bar" in the VbP Study ?
Yes and no. It can be done by adjusting the Volume at Price Multiplier for the chart, but this will adjust all the volume values for that chart. Just be sure you understand what is happening. Refer to the following: Chart Settings: Volume at Price Multiplier for Historical/Intraday Chart (Chart >> Chart Settings >> Chart Data >> Volume at Price menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2022-05-03 07:57:25] |
Hello: If I do the following according to the description: To manually set this, requires the use of value of 5 or higher. The size is a standard font point size. A recommended value would be 14 or higher. When set to a value of 5 or greater, the font will always stay the same size as the bar size changes. E.g. value 9, nothing happens, I would expect font size 9 now. Another problem I have is the following: If price moves out of the upper area of the screen, I have to manually adjust the display to move price back into the visible area. How can I automate that ? Date Time Of Last Edit: 2022-05-03 08:00:57
| [2022-05-03 14:38:33] |
You would need to make it larger than what the current font size is, then you can make it smaller. I.e. set the Width for that subgraph to a value of around 15 and apply, then change to 9, if 9 is what you want.
