Date/Time: Mon, 02 Nov 2026 06:55:52 +0000
Does anyone run SC on a laptop that doesn't meet the recommended 32gb RAM?
View Count: 806
| [2022-04-28 22:52:36] |
| CJBuckets - Posts: 20 |
just curious to see if everything is still usable and working in a timely manner since the laptop I want only has 16gb ram but meets the other two requirements (SSD and minimum 4-cores)
| [2022-04-29 05:01:46] |
16 GB is just fine.
