Date/Time: Wed, 28 Oct 2026 00:51:21 +0000
How to get statistics
View Count: 1762
| [2022-04-28 06:59:43] |
| Tofer - Posts: 38 |
Hello! I would like to create a couple of statistics, in order to detect unusual behavior. For instance, how could I get the average IB for the past X months? Id guess I can export that data to excel, and do the calculations there, just dont know how to get that specific value. Same goes for volume, to have the average of the overnight session for certain period. Of course would love to create more and more statistics, Im just lost with the way I can gather and export that data. Thank you very much! |
| [2022-04-28 09:10:30] |
| MFT_ - Posts: 12 |
I’m also pretty interested in this, but also a bit lost. I’ll keep an eye on this thread.
| [2022-04-28 15:01:19] |
| John - SC Support - Posts: 48345 |
To begin with, take a look at the Relative Volume study. It gives some powerful tools for comparing past data with current. You can base the study on other studies, so you are not limited to Volume. You will find the information here: Relative Volume In terms of how to the Initial Balance, you would need to use the Initial Balance study, as the IB is not directly available from the TPO study. Refer to the information here: Initial Balance For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
