Date/Time: Mon, 12 Oct 2026 16:18:50 +0000
how come the total volume is less than the ask vol and bid vol difference?
View Count: 1284
| [2022-04-25 05:47:49] |
| User749066 - Posts: 15 |
i used numbers bars study and the settings are column 1 - no text ,column 2 - ask vol bid vol difference , column 3 - volume but when it is plotted for some prices the delta is more than the total volume , how come the total volume is less than the ask vol and bid vol difference? i marked few of them with white arrows in the image. please refer the screenshot below. kindly check and let me know if I am missing any thing. |
| [2022-04-25 16:25:13] |
| John - SC Support - Posts: 48177 |
You would have to ask your data provider about this.
| [2022-04-25 17:15:18] |
sure john will contact data provider regarding this issue and will update the same
| [2022-04-26 07:47:50] |
the global data feeds ( my data vendor ) had a chat with them they are working with the development team of sierra charts to resolve the issue .
| [2022-04-29 10:00:16] |
Yes that is true.
| [2022-05-10 02:49:01] |
is the issue resolved ? will it be coming in next update? because i need to renew the sierra membership so if the issue has been resolved i will renew it or else will wait for the update
Date Time Of Last Edit: 2022-05-10 02:50:34
| [2022-06-03 05:00:27] |
Hi all , Sierra technical team , is the issue resolved yet as i need to update my plan if the issue resolved. |
| [2022-06-06 23:12:23] |
| Sierra_Chart Engineering - Posts: 25146 |
This is not yet resolved but it is something we are working with Global Data Feeds on.
| [2022-06-22 08:20:38] |
That is good.
| [2022-06-22 08:40:11] |
got a message from global data feed team that the issue is resolved now with the update thank you :)
| [2022-06-26 15:57:55] |
how to change the volume displayed on bid and ask to lot format (volume/lot size = number of lots traded) i.e the chart i trade have a lot size of 50 so if in the bid side the volume displayed is 50k then it should be displayed as 50k/50 = 1k lots traded how to do it? |
