Date/Time: Thu, 08 Oct 2026 15:07:06 +0000
[Programming Help] - Sierra Studies8 Function - compilation error.
View Count: 915
[2022-04-22 15:49:44]
User92573 - Posts: 619
Dear Support,
Do you have any thoughts why
Studies8.cpp, line: 4270 and the associated code for "PivotPointsDaily"
SCSFExport scsf_PivotPointsDaily(SCStudyInterfaceRef sc)
Won't compile and produces the following error message "error C3861: 'CalculateDailyPivotPoints': identifier not found"?
Many thanks.
PS I have posted on the Support Board 16 April but no replies and I need to use the function in my study - plus it is solely Sierra's code, with no additions that's producing the error.
Help appreciated. Many thanks
[2022-04-22 16:18:03]
John - SC Support - Posts: 48151
You can not compile the entire Studies8.cpp file, nor can you take out the function for scsf_PivotPointsDaily directly from the file without making some changes to it in order for it to compile on its own. Refer to the following:
How to Build an Advanced Custom Study from Source Code: Step-By-Step Instructions
[2022-04-22 18:25:44]
Hi John,
No, its the whole of the code related to "PivotPointsDaily" with the addition of headers and the dll reference.
What I don't understand is why it won't compile, or more precisely, why the "'CalculateDailyPivotPoints" function is not recognised?
I compile a lot of studies now and written a lot of albeit not complex acsil studies, so this is confusing.
Hove you tried the code?
Many thanks.
[2022-04-23 19:27:42]
User99735 - Posts: 234
Add #include "scstudyfunctions.h to your cpp file. It has "CalculateDailyPivotPoints" defined.
[2022-06-08 08:46:18]
Apologies User99735, I've only just noticed the reply.
Many thanks.
