Date/Time: Sun, 01 Nov 2026 08:37:54 +0000
Whats wrong with Euro
View Count: 1320
| [2014-04-24 12:54:00] |
| User88901 - Posts: 33 |
All my other symbols work but my Euro chart is not updating live. I use Sierra for data. Software version: 1102 | 2014-04-24 08:12:15 Usage end date: 2014-09-06 | 2014-04-24 08:12:15 Enabled for: Sierra Chart Historical Data Service. | 2014-04-24 08:12:15 Enabled for: Sierra Chart Real-Time Market Data Feed. | 2014-04-24 08:12:15 Enabled for: CME, CBOT, NYMEX, COMEX exchanges. | 2014-04-24 08:12:15 Received 1 data feed usernames. | 2014-04-24 08:12:15 Allow Support for Sierra Chart Data Feeds is enabled. | 2014-04-24 08:12:15 Active service: Interactive Brokers | 2014-04-24 08:12:15 Time Zone: -04:00:00 (EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2014-04-24 08:12:15 2014-04-24 08:12:15 Local computer clock time | 2014-04-24 08:12:15 2014-04-24 12:12:15 GMT time | 2014-04-24 08:12:15 2014-04-24 08:12:15 Time zone adjusted time | 2014-04-24 08:12:15 Time difference to server time: 1 seconds. | 2014-04-24 08:12:15 Program path: C:\Studies1\ | 2014-04-24 08:12:15 Data Files path: C:\Studies1\Data\ | 2014-04-24 08:12:15 OS Version Number: 6.1 | 2014-04-24 08:12:15 Date Time Of Last Edit: 2014-04-24 14:14:57
| [2014-04-24 14:13:39] |
This is now fixed. This problem was with one of the Sierra Chart servers. If you ever notice this again simply select File >> Disconnect and File >> Connect to Data Feed to switch to the other server. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2014-04-24 14:18:29] |
| HalGE - Posts: 39 |
Disconnect and reconnect does nothing to help the [M] oil datafeed
| [2014-04-24 14:33:29] |
The CL June 2014 data feed is working. Are you seeing a problem with that? What is the specific symbol?
