Date/Time: Fri, 30 Oct 2026 03:27:01 +0000
Can I use C++20 with Visual Studio 22 for ASCIL Studies?
View Count: 1194
[2022-04-09 14:09:31]
YSS - Posts: 120
Can I use C++20 with Visual Studio 22 for ASCIL Studies when I select Build with Visual C++ - Release ?
[2022-04-10 23:42:58]
Yes should not be a problem. Newer versions of Sierra Chart let you control the path to the compiler. On the Build Studies window.
