Date/Time: Sat, 14 Nov 2026 08:04:05 +0000
NO DATA ON MY CHARTS
View Count: 843
[2022-04-07 17:29:27]
User483839 - Posts: 15
HI i amnot getting any data on my charts, can someone please help me
[2022-04-07 18:26:23]
What is the symbol for one chart for which you are not getting data?
[2022-05-03 17:10:31]
I AM not having any data on my charts symbol is EPM22
[2022-05-03 17:35:51]
We see that you are connecting to CQG. Therefore the symbol you should be using the following:
F.US.EPM22
If you are not using the correct symbols then you can easily change them for all your charts by opening your chartbooks and selecting Edit >> Translate Symbols to Current Service.
