Date/Time: Fri, 30 Oct 2026 03:28:03 +0000
Missing cumulative numbers for bid pulling/stacking column
View Count: 1288
| [2022-04-06 13:43:00] |
| Jeff Li - Posts: 74 |
Hi there, there used to be a white number showing the cumulative bid pulling/stacking values on both the ask and bid columns on my chart dom. Not sure why but it's now disappeared. Any advice? |
| [2022-04-06 14:53:23] |
| John - SC Support - Posts: 48369 |
It is still there. If you are not seeing it then most likely that is because the value is very far up/down and you would have to adjust the scale to see it. The other solution it to limit the number of Pulling/Stacking levels - refer to the following for this: Global Trade Settings Windows: Maximum Bid/Ask Market Depth Pulling/Stacking Levels (Global Settings >> Chart DOM Settings >> Other >> Other Settings) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2022-04-07 12:42:54] |
Hi John, I minimized the scale to 10k on ES and was not able to find it. My global trade setting window for dom stack depth was set previously to 24 and currently still 24. |
| [2022-04-07 14:54:33] |
Can you please give us a screenshot of what you are seeing by following these instructions: Support Board Posting Information: Attaching or Posting a Screenshot/Image (Optional) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
