Date/Time: Sat, 31 Oct 2026 16:37:08 +0000
DOM
View Count: 776
[2022-04-04 13:46:32]
User696827 - Posts: 15
since the new update was installed, only one order is visible. Same is whit heatmap.
how to set up, to see more orders?
imageheatmap.jpg / V - Attached On 2022-04-04 13:45:47 UTC - Size: 1.87 MB - 232 views
imagedom.jpg / V - Attached On 2022-04-04 13:46:00 UTC - Size: 4.58 MB - 249 views
[2022-04-04 13:47:40]
You are using data from Rithmic. So you need to contact them about this. If you want help from Sierra Chart, then you need to use our Denali Exchange Data Feed. For more information, refer to:
Rithmic Trading Platform Service: Rithmic Support Policy
Date Time Of Last Edit: 2022-04-04 13:47:59
