Date/Time: Thu, 19 Nov 2026 13:27:30 +0000
[Locked] - Order Quantity " Value " no longer selected by DEFAULT - Resting Order (Adjustment)
View Count: 894
| [2022-03-29 11:22:12] |
| User991052 - Posts: 33 |
Hi, Order Quantity " Value " in Dialogue Box no longer selected by DEFAULT when pop-up window appears. ALL versions of Sierra pre-2356 have this functionality. Users now have to " manually " select value in the Dialogue Box (pop-up window) before inputing new quantity. This is having a serious impact on workflow and the ease in which orders can be adjusted. “ No “ interaction was previously required between Mouse & Dialogue Box to adjust (input) value to update order. This was a three step process: Left Click " Quantity " - Resting Order, Enter " Value " - Keyboard, Press ENTER Q. Are you aware of this change ? if so, why has Sierra introduced this change which has essentially added an EXTRA STEP for users who relied on this functionality (shortcut) to manage orders? Date Time Of Last Edit: 2022-03-29 22:11:56
| [2022-03-29 12:38:35] |
We will check on this. It should be selected that quantity field and the existing quantity value highlighted.
| [2024-08-16 12:24:39] |
| Eranox - Posts: 41 |
Have you solved? I need the possibility that every order I add to an existing resting order at the same price is automatically added to the quantity field so that I can move them as an unique order.. |
| [2024-08-16 18:16:09] |
| Sierra_Chart Engineering - Posts: 25441 |
This thread is unrelated to what you are asking for. Sounds like you want to use Scale In functionality: Attached Orders: Scaling In Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
