Date/Time: Sat, 31 Oct 2026 16:39:25 +0000
Condensed Pricing Chart - Levels Forced to be Visible
View Count: 779
| [2022-03-27 19:45:27] |
| User505884 - Posts: 11 |
Hi, Sierra is condensing price on 1 of my charts by forcing a study to be visible. On the attached image, you will see that the red line at the bottom of the chart (a previous low from the Daily OHLC study) is forced to be visible which condenses my price chart. How do I change it that the levels are not forced to be visible. I want the price chart to take up the whole screen. https://www.sierrachart.com/image.php?Image=1648410117717.png |
| [2022-03-27 19:48:11] |
I have to set scale as 'same to region'. Got the answer after further investigation - Chart Scale and Scale Adjusting: Opening the Scale Settings Window For a Study Thanks |
| [2022-04-03 01:20:07] |
For future reference here is the relevant documentation: Chart Scale and Scale Adjusting: Basing Scale Only on Price Bars Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-04-03 01:20:15
