Date/Time: Sat, 31 Oct 2026 18:08:01 +0000
rhythmic direct not support on package
View Count: 1032
[2022-03-25 17:24:10]
User661036 - Posts: 7
I trade through infinity brokers and I also started trading with topstep, but when I go to trade>data/trade service settings and then try to select Rithmic Trading -DTC(not enabled on package). why is this and what do I need to do to enable Rithmic? Thanks.
[2022-03-25 17:38:49]
You really should not be getting that. We have removed the old affiliation with TransAct from your account, just to be sure.
Please exit from Sierra Chart and then start it again and see if you have the same issue.
If you do have the same issue, then select Help >> About and tell us the Account Name that is shown in there.
[2022-03-25 19:00:09]
You need to be running service package 10 or higher, to use Rithmic.
To change your Sierra Chart Service Package, select "Help >> Account Control Panel" on the Sierra Chart program menu. On the displayed webpage, click on the "Set Service Package for Renewal" link.
Or go to this page:
https://www.sierrachart.com/UserControlPanel.php?page=ServicesActivation
You will need to login if you are not currently logged in.
In the "Available Services >> Choose Usage Time Service Package" frame, select the Service Package that you want to set your account to. Press the "Set" button.
The remaining service usage time on your account will be adjusted based upon the cost of the package you are changing to. If the new package is a higher-priced package, then the usage time will be reduced due to the higher price.
There is no charge for changing your Sierra Chart service package. Only your Sierra Chart account usage time ending date is adjusted.
When changing between Sierra Chart Service Packages, the usage time ending date on your Sierra Chart account is adjusted based upon the price differences between the package you are changing from and the package you are changing to.
When changing to a higher priced package, your usage time ending date will be brought back closer in time. When changing to a lower-priced package, your usage time ending date will be brought forward further out in time.
Date Time Of Last Edit: 2022-03-25 19:00:34
