Date/Time: Thu, 26 Nov 2026 04:11:38 +0000
ZigZagText Color
View Count: 1181
| [2022-03-25 08:03:30] |
| AKR - Posts: 549 |
I would like to have the text for a zigzag (eg. the Delta in my case) to be colored acourding to if it is a pos or neg vale. What it does is to color is if it is an uptrend or downtrend. Also changing the auto coloring to "based on +/-" does not change that. Is that not supported, or am I doing something wrong. See pic. |
| [2022-03-25 15:03:47] |
The ZigZag only colors based on the Up/Down trend. There is not an option for coloring based on Positive/Negative values. You can modify the study itself to get what you need. The code is in the file Studies7.cpp which is located in the ACS_Source folder under your main Sierra Chart installation. Refer to the information here: How to Build an Advanced Custom Study from Source Code For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-04-24 16:17:21] |
This is now available in version 2901 (currently the Pre-Release). Set the following to view this: - Volume to Accumulate: Ask Bid Volume Difference - Display Zig Zag Volume: Yes - Text Labels subgraph (SG2) >> Auto Coloring: Based on +/- The displayed volume will then be colored the Primary subgraph color for positive values and the Secondary subgraph color for negative values. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
