Date/Time: Sat, 31 Oct 2026 18:08:21 +0000
Horizontal Line Increment & Scale Increment(Y-axis)
View Count: 1015
| [2022-03-25 06:14:56] |
| User324663 - Posts: 4 |
Thank you, SC, for your outstanding product. Where, pls, are the controls for Horiz. Line Increment & Scale Increment? After updating to SC version 2375 64-bit, I've searched on the new Chart Settings menus, but I've failed to find these two functions. The new '[Scale]' menu does not seem to have them. In the past, clicking on Chart Settings>Scale always got to these. Thank you in advance for your assistance. I searched the new menus, the SC instructions & Support Board. Sorry if you've already covered this question.
| [2022-03-25 14:09:34] |
| John - SC Support - Posts: 48377 |
You can still get to it the same way. Select Chart >> Chart Settings >> Scale and at the top is an item that states (Button) on the left and [Scale] on the right. The item that states [Scale] is the actual button, so selecting that will open the Scale Settings window. You can also access the Scale Settings more directly by left-clicking on the Price Ladder for the chart and selecting Scale Settings. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
