Date/Time: Sat, 31 Oct 2026 18:08:02 +0000
Time and Sales columns and data not corresponding v2374
View Count: 824
| [2022-03-25 04:31:40] |
| dbtrade - Posts: 24 |
I am posting a picture of the Time and sales with incorrect column and data correspondence. The Time column shows the date, the Price Column shows the Time and the Volume column shows the price. I noticed this after upgrading to v2374 |
| Attachment Deleted. |
| [2022-03-25 06:46:31] |
| User216169 - Posts: 17 |
I had the same problem which was resolved when I installed V. 2375
| [2022-03-25 07:58:16] |
Yes update to 2375 or higher.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-03-25 07:58:20
| [2022-03-25 12:24:43] |
I didn't realize there had been an update, thanks.
