Date/Time: Sat, 31 Oct 2026 18:08:54 +0000
moving to Stage 5/ Sierra Futures
View Count: 1188
[2022-03-24 11:19:44]
User327376 - Posts: 13
Hi, I am moving my account from Infinity to Stage 5/ Sierra Futures in the next few days. Is there anything I need to be aware of for a smooth transition and avoid double billing and/ or anything you can think of would greatly appreciated.
Thank you
G
[2022-03-25 13:39:37]
Nothing you need to do in regards to your Sierra Chart account. Other than changing to Service Package 11:
To change your Sierra Chart Service Package, select "Help >> Account Control Panel" on the Sierra Chart program menu. On the displayed webpage, click on the "Set Service Package for Renewal" link.
Or go to this page:
https://www.sierrachart.com/UserControlPanel.php?page=ServicesActivation
You will need to login if you are not currently logged in.
In the "Available Services >> Choose Usage Time Service Package" frame, select the Service Package that you want to set your account to. Press the "Set" button.
The remaining service usage time on your account will be adjusted based upon the cost of the package you are changing to. If the new package is a higher-priced package, then the usage time will be reduced due to the higher price.
There is no charge for changing your Sierra Chart service package. Only your Sierra Chart account usage time ending date is adjusted.
When changing between Sierra Chart Service Packages, the usage time ending date on your Sierra Chart account is adjusted based upon the price differences between the package you are changing from and the package you are changing to.
When changing to a higher priced package, your usage time ending date will be brought back closer in time. When changing to a lower-priced package, your usage time ending date will be brought forward further out in time.
You also need to complete the market data agreements:
https://www.sierrachart.com/UserControlPanel.php?page=ExchangeAgreements
We would recommend waiting before activating the CME exchange fee for market data until April and then you get that month free. Also contact Transact to make sure you are not billed any further exchange fees from them.
You can activate exchanges here:
Here are the instructions for the Teton order routing service:
Sierra Chart Teton Futures Order Routing: Setup Instructions
Date Time Of Last Edit: 2022-03-25 13:42:49
