Date/Time: Sat, 31 Oct 2026 18:08:21 +0000
[Locked] - Centering DOM on price fixed?
View Count: 2414
| [2022-03-24 05:15:20] |
| user_xyz - Posts: 529 |
The latest release has "Added support, for re-centering to the exact last trade price on a chart, when using the Re-center Trade DOM Scales command." and referencing thread is locked. Does this address or have the ability now to keep the price dead center in the DOM without the horizontal rows bouncing around? I tested this out and still cannot find a way to lock the DOM down and have the price smoothly scroll up/down. My solution has been to set scale to manual and keyboard shortcut "space" to Re-Center DOM on price when it goes outside of range. Otherwise clicking bid/ask nearly always bounces during a click to another intended price. Major gripe with the SC DOM... Thanks! |
| [2022-03-25 13:06:38] |
| Bango - Posts: 76 |
[feature request] RECENTER CHART ON LAST PRICE ON DEMAND
| [2022-03-25 13:34:36] |
This is supported: Does this address or have the ability now to keep the price dead center in the DOM without the horizontal rows bouncing around? I tested this out and still cannot find a way to lock the DOM down and have the price smoothly scroll up/down. Refer to: Chart Scale and Scale Adjusting: Constant Range (Scale Range) This is what you want to use: Constant Range Scale Modes >> Re-Center To The Last Price On Every Update
| [2022-03-25 16:55:06] |
I've tried that but the bid/ask columns are bouncing around making it impossible to click accurately into a bid/ask row. The price should be locked dead center of the window with smooth scrolling around it. This isn't useable in this configuration you can never accurately set a limit order. See attached video... Date Time Of Last Edit: 2022-03-25 16:56:57
Private File |
