Date/Time: Fri, 16 Oct 2026 03:34:50 +0000
Transact disconnection - TT broker for assistance
View Count: 702
[2022-03-23 21:10:23]
User146252 - Posts: 9
I currently have an account with you folks through Transact......This relationship is ending. To successfully switch you provided the following in your notification:
1. You will need to move to a new broker and use our Teton Order Routing Service which replaces Transact:
We will make this process very easy. If you need help, just simply post here and we will have a broker contact you. Or you can choose one among the list at step 2 here:
Sierra Chart Teton Futures Order Routing: Setup Instructions
The process of moving to a new broker is very easy and they handle the transition for you. Much easier than moving to a new trading platform.
I would like to have a broker contact me to assist me with this process. 608 719-7272 Central Time
[2022-03-23 21:16:46]
Stage 5 Trading - Posts: 155
Hi Trader,
A Stage 5 Trading broker will reach out to you shortly. We look forward to assisting you in transitioning to an improved setup!
Best,
Anthony Giacomin
Stage 5 Trading
Trading derivatives carries a high degree of risk, and may not be suitable for all investors. Past performance is not necessarily indicative of future results.
