Date/Time: Sat, 31 Oct 2026 18:08:01 +0000
Feature Request - Adding User Text/Labels to Rectangles, Lines, extended Rectangles
View Count: 812
[2022-03-23 18:01:02]
HumblyTrading - Posts: 224
Hello SC Team,
I wonder if it is possible to add a feature to lines and rectangles which would allow the user to type a line of text which would serve as a table for that object?
For example, I may draw an extended rectangle or ray based on the weekly time frame. I would love to add a label to that object stating "Weekly."
Similarly, I may draw a rectangle around some price action and label it "Range Bound," or many other labels.
Currently, I can at least use a separate text object, but it would make better use of SierraChart's versatility and power if I could have custom configurations for objects that included these user defined comments/labels.
Thank you for your consideration,
Mike
