Date/Time: Sat, 31 Oct 2026 18:08:05 +0000
setting up sierra chart cme routing service
View Count: 902
| [2022-03-23 15:15:28] |
| si_ - Posts: 3 |
Just sent a request to Dorman to set up my Sierra Chart CME routing service and got an e mail back asking for symbols to be traded and quantities of contracts for each symbol . What do Dorman need this info for ? Can I not trade anything and are bound my margin requirements for quantaties of contracts ? |
| [2022-03-23 15:22:29] |
Who is your account previously with? Was it with Dorman? For the Teton order routing service, Dorman does have to specify what contracts you can trade and the maximum position limits. This really is not unusual. Many order management systems do work this way. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2022-03-23 15:29:07] |
| si_ - Posts: 3 |
Yes the account was previously held with Dorman . Ok thats fine then . And if I want to change it I have to notify Dorman first ? Limits and symbols is a rigid arrangement? |
| [2022-03-23 16:03:48] |
Best you talk with Dorman about this. It is not appropriate for us to get into the middle of this.
| [2022-03-23 17:56:31] |
| si_ - Posts: 3 |
Ok Thanks . Just trying to figure out what is normal .
