Date/Time: Sat, 31 Oct 2026 18:08:00 +0000
Calculation Error of Initial Balance in VbP for TPO Chart Study
View Count: 696
| [2022-03-22 16:31:58] |
| User470516 - Posts: 78 |
Dear SC Team, Data are the FDAX data. I have represented the IB on a daily chart using the "High/Low For TimePeriod Study" overlaid on a daily chart from an hourly FDAX chart and I have compared the result with the IB Range high and low as computed in the "VbP for TPO Chart Study". There are frequent discrepencies between the two sources of calulation. The error is in : "VbP for TPO Chart Study". For example toaday 2022/03/22. The low of the day which is marked during the first hour (8AM bar) is 14313 (this can be verified on both the "VbP for TPO Chart Study" (using chart values for tools) and on any intraday chart). The IB Range Low in the "VbP for the TPO Chart Study" says 14314. This kind of error happens almost all the time and affects both the IB range Low and High calculation. Best regards. |
| [2022-03-23 20:12:29] |
We are not really going to be able to understand this unless we get that chart. Provide it by following these instructions: Support Board Posting Information: Providing Chartbook with Only a Single Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
