Date/Time: Sat, 31 Oct 2026 18:08:52 +0000
GOOD DAY !
View Count: 687
| [2022-03-21 15:13:08] |
| User413489 - Posts: 21 |
Can you please tell me how to adapt the drawing objects to other graphs of this tool?
| [2022-03-23 17:42:39] |
| John - SC Support - Posts: 48377 |
We are not sure exactly what you are asking, but refer to the following which will hopefully answer your question: Chart Settings: Copy Chart Drawings from Chart #'s (Chart >> Chart Settings >> Chart Drawings menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
