Date/Time: Sat, 31 Oct 2026 18:47:43 +0000
How to show several DOMS, different symbols
View Count: 1474
[2022-03-17 17:11:00]
User737477 - Posts: 19
Hi guys,
I'm trying to build a setup which lines up several DOMS showing different symbols - try as I might, when I duplicate a DOM [because its the only way I know to re-create a DOM with my desired settings], when I go to detach and change symbol on that newly created DOM, the symbol changes for all charts / DOMS. How do I stop this from happening please? My end result is DOMS lined up against each other showing the different treasury futures.
Many thanks,
Alun
[2022-03-17 17:31:23]
It sounds like you have your original DOM setup with a Link to have the same symbol. Therefore, when you duplicate it, that link option copies over. Refer to the following:
https://www.sierrachart.com/index.php?page=doc/ChartSettings.html#LinkNumber
By the way, using Duplicate Chart and changing the symbol is the correct way to get a new DOM with the same setup as another one.
