Date/Time: Sat, 31 Oct 2026 18:47:05 +0000
Study price overlay not working
View Count: 968
| [2022-03-17 10:51:45] |
| User97684 - Posts: 136 |
Hi , pls help For some reason the VPOC line from the 'value area line' study, can not be overlayed onto a different chart. pls see attched. Many thanks |
Attachment Deleted. Private File Private File |
| [2022-03-17 14:18:03] |
| John - SC Support - Posts: 48377 |
Please get us a chartbook with those two charts in it so we can take a look. Follow these instructions to get us the Chartbook, except you will be sending 2 charts instead of just 1: Support Board Posting Information: Providing Chartbook with Only a Single Chart For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2022-03-18 10:47:39] |
Thanks John, pls see attched, |
| [2022-03-18 17:20:39] |
It is not a matter of not being able to be overlaid, it is just a matter of the data showing on the other chart. In particular, with the images you provided, the POC is only displaying until about 20:45 on 3/16, but you do not have that time displaying in the other chart so you will not see the line. Additionally, you will not see the Name Label in this situation. Just make sure you are seeing it on the same times on both charts. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
