Date/Time: Sat, 31 Oct 2026 18:08:01 +0000
Trade on Chart Volume Profile Columns
View Count: 889
| [2022-03-15 15:38:30] |
| User337568 - Posts: 65 |
I use the trade on Chart DOM, and I find these two columns redundant. Where do I find these columns? Thank you |
| [2022-03-15 16:45:22] |
| John - SC Support - Posts: 48377 |
Refer to the information here: Global Trade Settings Windows: Customize Chart/Trade DOM Columns (Chart Specific) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2022-03-15 20:22:08] |
Hi: Still not getting it. I believe these columns are "Current Traded Bid/Ask" as I can clear them when I right-click on Scale. However, I don't have the settings in the attached window. |
| [2022-03-15 23:39:18] |
Are you running any 3rd party studies that might be adding those in? If you can get us a copy of the chart in a chartbook of its own, then we can take a look and see if we can figure out where they are coming from. Refer to the following instructions: Support Board Posting Information: Providing Chartbook with Only a Single Chart For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2022-03-19 02:47:34] |
I deleted all the studies and I could not find the Current Traded Bid/Ask Volume Columns
| [2022-03-23 15:21:36] |
Everything shows up properly when we open the Chartbook you sent. Attached is an image of what we see. This chart looks different from the one you show in your image. Does this chart also not show all the columns when you select Trade >> Customize Chart/Trade DOM Columns? For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-03-23 15:21:55
| [2022-03-23 16:42:19] |
Thank you for the location information. It helped me discover that I was on the wrong chart. I kept looking at my main chart instead of the detached chart. I got your image when clicking Trade >> Customize Chart/Trade DOM Columns on the detached and not the main chart. Thank you for being so helpful. |
