Date/Time: Sat, 31 Oct 2026 18:07:49 +0000
How to change foots only in DOM
View Count: 901
| [2022-03-15 03:33:28] |
| User360283 - Posts: 538 |
After my local PC repair shop "fixed" my PC the stand alone DOM is not readable. FLAT, P&l, DPL, etc. are very faint. I've hunted around MSFT for 2 days and can't find an answer. Help please. Thanks
| [2022-03-15 14:33:15] |
| John - SC Support - Posts: 48377 |
Can you please give us a screenshot of what you are seeing so we know exactly where the issue is. You can attach an image by following these instructions: Support Board Posting Information: Attaching or Posting a Screenshot/Image (Optional) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2022-03-15 21:06:25] |
here it is thanks |
| Attachment Deleted. |
| [2022-03-22 15:08:04] |
help please thanks
| [2022-03-22 19:32:28] |
The font of those is controlled by the operating system. It has been our long-term plan to implement a new Trade Window based upon our control bar, which will allow these sizes to be customized. We will see if we can at least prioritize getting new controls supported on our control bar for these particular fields of information from the Trade Window.
