Date/Time: Sat, 31 Oct 2026 19:27:50 +0000
Submit Micro Trades with Mini Trades
View Count: 1277
| [2022-03-11 20:59:41] |
| User379468 - Posts: 508 |
Maybe similar to the trade allocation to other accounts feature: Could there be a way to natively and automatically in Sierrachart concurrently submit orders of a micro contract with a mini contract, in the same account? ie, Buy 1 ES, also submits buy 2 MES. |
| [2022-03-11 21:24:52] |
| John - SC Support - Posts: 48377 |
There is not built-in support for this. You could create a custom study to do this, or have someone develop it for you. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2022-03-12 03:21:02] |
| Tonkadad - Posts: 235 |
Why not just 12 MES.
| [2022-03-12 03:51:14] |
Why not just 12 MES. It's more expensive in slippage and commissions. If high volume, it adds up. Difference can be greater on others like MCL, MGC, and with more contracts, etc. |
| [2022-03-12 04:49:46] |
Excellent point! I didn't think that thru at all.
| [2022-03-12 23:31:11] |
| 1+1=10 - Posts: 270 |
From a custom study perspective, this is actually a pretty easy task. (I write a lot of custom studies, however I typically don't for hire.) Here's a list of active SC custom study (ACSIL) programmers -- especially the first two. 1. https://forgivingcomputers.com/ -- this is the site for SC user bradh. You contact through the forum's direct messages here: https://www.sierrachart.com/SupportBoard.php?do=UserProfile&UserID=28830 2. https://www.simplesystemtrading.com/?link=x (active -- here's his twitter: https://twitter.com/sstfrederik) 3. https://www.fiverr.com/synergy0911/create-any-trading-code-for-ninjatrader-tradingview-mt4 (it says SC ACSIL in as profile when you scroll down) 4. https://www.upwork.com/freelancers/~01e7a1b7a2edd4853a/ Good luck with your trading! |
