Date/Time: Wed, 28 Oct 2026 17:11:38 +0000
Send Attached Orders by Position
View Count: 1242
| [2022-03-11 14:33:43] |
| User104854 - Posts: 460 |
I use this feature in the event my attached orders get cancelled. I have it on my chart trade menu and it works great. The only thing is it only places 1 contract on the stop and target even if I have more than 1 contract on the existing position. I only use 1 stop and 1 target. Is there a setting that I need to make to so that it matches the contract sizes on the attached orders to the number of contracts on the existing position? Can this be fixed? I'm currently using version 2348 if that matters. Thank you. |
| [2022-03-11 14:49:33] |
You just need to adjust the Order Quantity on the Trade Window for the chart, to what you require: Basic Trading and the Trade Window: Main >> Order Quantity (Quantity) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-03-11 14:49:48
