Date/Time: Fri, 26 Apr 2024 06:34:15 +0000
[Locked] - Pricesquawk not working on version 2362
View Count: 5853
[2022-07-26 20:15:40] |
This is already been done for your account. What exchanges are you looking to receive data for over the DTC protocol server?
[2022-07-30 19:10:09] |
User550539 - Posts: 27 |
Hi, the exchanges I am looking to receive data over are the full CME Group (CME, CBOT, COMEX, NYMEX). On my main instance, I have ZT, ZF, ZB, ZB, UB, ES, YM, CL, and GC DOMs open but on my price squawk it loads up different exchanges that I am not subscribed to (as seen in screenshot). I can get pricesquawk to work with a previous version of SC loaded on the side, but I would like to consolidate it into one. My ports are set correctly, not sure why this issue is coming up. My current SC version is 2419 |
2022-07-30_15-06-20.png / V - Attached On 2022-07-30 19:09:56 UTC - Size: 30.89 KB - 133 views |
[2022-07-30 19:57:59] |
We do not know what the problem is. You need to contact price squawk: but on my price squawk it loads up different exchanges that I am not subscribed to (as seen in screenshot).
[2022-08-04 12:05:04] |
Mercrastius - Posts: 26 |
I've been considering getting a price squawk trial, but if making it work will be a headache I'll just skip it. If SC will be adding similar functionality I'd wait for that, but I understand it's not a priority. I'm using version 2419, denali CME data/teton order routing. I only need the ES symbol. Would I be able to trial price squawk with my current setup? If so, what's involved? For those using price squawk, what's your take on it? Worth the setup hassle / expense? Thanks to all. Date Time Of Last Edit: 2022-08-04 12:05:29
[2022-08-04 12:26:41] |
Sierra_Chart Engineering - Posts: 14092 |
No, we can authorize the data for you: but if making it work will be a headache I'll just skip it.
Let us know when you begin the trial. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-08-22 14:54:32] |
User438057 - Posts: 49 |
Hi SC, could you please allow the new PS integration into my account. Regards |
[2022-08-22 15:01:40] |
Yes this has already been done. What symbol are you using?
[2022-08-22 18:18:47] |
ES,NQ,YM,RTY,and the related Ticks, most of the time. Do you have to set it up for each symbol? And will it then work also with Rithmic? |
[2022-08-22 19:17:00] |
There are no restrictions on the Sierra Chart side for your account regarding this.
[2022-08-25 19:23:24] |
User911964 - Posts: 7 |
I am on 2425 version and pricesquawk shows successfully logged onto Sierra DTC Server, but doesnt detect the symbols. I only want ES and NQ from CME. I have already checked Yes for Auto Send Security Definition for new symbols. If any adjustment needed for my account. Kindly do so. Thanks |
[2022-08-25 21:51:56] |
Restart Sierra Chart and try again.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-08-25 21:52:02
[2022-08-25 23:56:32] |
traderacefly - Posts: 57 |
Just fyi, I'm on SC 2425 with the latest version of PriceSquawk and it is working fine. I'm using the Denali data feed (see screenshot)
Date Time Of Last Edit: 2022-08-26 01:57:48
2022-08-25_20-55-29.png / V - Attached On 2022-08-26 01:57:00 UTC - Size: 115.06 KB - 132 views |
[2022-08-31 16:07:39] |
JeremyC - Posts: 1 |
Could this adjustment to allow PriceSquawk to work be made on my account too please? Thanks!
[2022-09-01 11:00:11] |
This is done.
[2022-09-01 12:53:50] |
Bango - Posts: 76 |
Any news regarding Eurex contracts?
[2022-09-01 12:57:36] |
Yes, we cannot allow market data for EUREX. The exchange has strict rules regarding this.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-09-01 12:57:51
[2022-09-15 07:07:21] |
User167639 - Posts: 1 |
Hello, Using v2438, PriceSquawk can connect to the DTC server but will not list the symbols from the CME. Other symbols such as XUAUSD will get listed though. The Sierra Chart message log states the the ES will not be relayed. When I install v2348 instead, everything works fine. In both cases I'm using the delayed data feed provided by Sierra Chart (as I'm still in trading in simulation mode) Is there something on my account that has to be changed so I can use the latest version of Sierra Chart with my PriceSquawk? Thank you |
[2022-09-15 21:12:44] |
User820791 - Posts: 15 |
Is it possible to make the adjustment on my account as well? Thanks. |
[2022-09-20 00:09:01] |
User293778 - Posts: 17 |
Hi, can you allow the pricesquawk integration for my account too? Symbols: ES, NQ, ZN, ZB, CL. Eurex also if it is possible now: BUND, MiniDAX and STOXX50. Thnaks. |
[2022-09-20 08:53:56] |
Regarding post #41, #42 and #43, you can now access the CME data with PriceSquawk. This does not apply to EUREX. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-10-17 00:19:36] |
HappySalguero - Posts: 1 |
could you allow the pricesquawk integration for my account
[2022-10-17 15:16:31] |
John - SC Support - Posts: 31131 |
HappySalguero - We have taken care of this for your account.
[2022-11-07 22:19:48] |
User395222 - Posts: 1 |
Requesting pricesquawk integration for my account. thank you.
[2022-11-08 16:42:51] |
User395222: We have enabled this for your account. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-11-13 20:04:10] |
thebeej - Posts: 5 |
Please allow for my account as well. Thanks! |
[2022-11-13 20:39:39] |
This is done.
