Date/Time: Sat, 31 Oct 2026 19:27:48 +0000
wich package should i use if i want to paper trade?
View Count: 818
| [2022-03-09 01:14:39] |
| Sivle - Posts: 87 |
i want to paper trade or do sim trading. with package should i use to be able to use sierra chart with delayed data feed. i am going to trade futures like MES and other. appreciate help. |
| [2022-03-09 02:37:20] |
You will need our Standard Service Package 3: Description of Service Packages and Pricing Follow these instructions to add usage time to your Sierra Chart account:
1. Select "Help >> Account Control Panel" on the Sierra Chart software menu. On the displayed webpage, click on "Activate Services". Or you can also go to this page in your browser: https://www.sierrachart.com/UserControlPanel.php?page=ServicesActivation Login with your Sierra Chart Account Name and Password. 2. Choose the particular Service Package that you want to automatically renew and press the "Update/Set" button. 3. Add sufficient credit to your Services Balance using any of the available payment options: https://www.sierrachart.com/UserControlPanel.php?page=AddAccountCredit For further information, refer to: Sierra Chart Purchase and License Information: Renewing Access Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-03-09 02:37:39
