Date/Time: Mon, 19 Oct 2026 03:00:45 +0000
Move chart to last candle/bar - button
View Count: 1724
[2022-03-07 12:32:47]
User361939 - Posts: 170
During using alerts i come up with simple idea to work simplier with alert on sierra, but i don't know how to do it.
When alert occurs i double click on alert and automatically i will be transfered into chart and exact bar where alert happened.
Now every single time i need manually move chart to last candle (when i use a lot of alerts it;s becoming enoying, sometimes i can forget to move chart to last candle which can couse additional problem for trader.)
Is there a way to create control button, so when i click on it chart will always go to the last candle?
If there is not, would you consider adding this option?
Best Regards
Date Time Of Last Edit: 2022-03-07 12:35:27
[2022-03-07 19:13:36]
Tonkadad - Posts: 235
If you want to go to the last bar (live bar) you can click "End" on keyboard, you know if you are looking at live data if in bottom right corner of chart the box is green.
I have it setup with a mouse click, alot of mouse software allows you to use buttons on mouse to emulate keyboard strokes, really handy.
