Date/Time: Mon, 12 Oct 2026 02:51:13 +0000
[Locked] - Maximum historical Intraday days to download setting not respected
View Count: 793
[2022-03-04 14:17:50]
BenjFlame - Posts: 353
I set max "Non-tick Data" to 16 days (15 for ticks).
I delete all intraday files.
I restart and reconnect, open my chartbook: it stubbornly downloads data all the way back to 2021 11 23.
Additionally, in chart settings, upon initial download, the "Use number of days to load" which is set to 10 is ignored, I must "reload and recalculate chart" for this setting to be respected.
So how can I FORCE the system to download only the amounts of days specified?
[2022-03-04 14:21:55]
That setting will not be followed when using Continuous Futures Contract charts. So definitely do not use these types of charts.
This can also be the case based upon the contract month.
Refer to the documentation for this setting:
Consult the documentation first before posting. This is so clearly explained in the documentation. Everything in your post is explained in the documentation.
There is nothing further we can do for you. There are no problems here at all. You just need to understand how things work.
Date Time Of Last Edit: 2022-03-04 14:30:32
