Date/Time: Sat, 31 Oct 2026 20:11:48 +0000
[User Discussion] - VBP alert - config help
View Count: 946
| [2022-03-03 11:54:23] |
| VolTrader73 - Posts: 139 |
Hello. Trying to highlight those sweeps (volume at one side only, for example 4 ticks at which trades went off the ask only as market moved fast). Please see attached screen shot. What did I miss ? I used Ask volume Bid volume ratio of 1200 or -1200. To capture those sweeps I assumed any value would do as one side is ZERO. Please advise |
| [2022-03-03 12:13:57] |
| User907968 - Posts: 885 |
No, because you have Zero Value Compare Action set to Set Percentage to +/- 1000%, and as 1200 is greater than 1000, the zero compare levels will not register. |
| [2022-03-03 13:07:07] |
Hello and thank you User907968. That seemed to fix part of the problem. Still, how do I isolate only those 100% sweeps on one side only ticks ? And is it possible to screen only those sweeps of 2,3 tick levels and above so for example I will not get a notification on the highest/lowest ticks in the bar. Date Time Of Last Edit: 2022-03-03 13:08:26
| [2022-03-03 13:21:46] |
Does the attached chartbook help at all?
| [2022-03-03 13:32:00] |
I really appreciate it. Thank you much User907968! |
