Date/Time: Wed, 07 Oct 2026 19:49:05 +0000
Lock Screen View
View Count: 928
| [2022-03-02 20:56:34] |
| Marlin46 - Posts: 34 |
When scrolling back or forward in time on a candle chart is there a way to lock the screen picture so that the candles or OHLC bars stay on the screen and do not go up or down out of sight as you scroll backward and forwad in time? Thanks in advance, hope that makes sense. Thanks for all the help you have provided.
| [2022-03-02 21:54:37] |
| John - SC Support - Posts: 48139 |
You need to adjust the Scale settings to do what you want, although we are not sure exactly what you are looking for given what you have stated. Since you say the bars are both going "up and down" and "out of sight" then we are not sure what your current setting is, or what will work best for you. Therefore, play with the different options available until you find a scale setting that works best for you. Refer to the information here: Chart Scale and Scale Adjusting: Scale Range (Scale Settings) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
